Каяк для серфа
maratovich
Re: Каяк для серфа
Сообщение maratovich » 06 ноя 2020, 13:26
Последний раз редактировалось maratovich 06 ноя 2020, 14:42, всего редактировалось 1 раз.
maratovich
Re: Каяк для серфа
Сообщение maratovich » 06 ноя 2020, 13:35
maratovich
Re: Каяк для серфа
Сообщение maratovich » 06 ноя 2020, 19:29
Там была группа из Калифорнии, один явно косил под актера из фильма про серферов. И они были на коротких досках, не как наши сейчас ходят фотаются и лежат на берегу на трехметровых матрасах ))
Re: Каяк для серфа
Сообщение HEKOT » 06 ноя 2020, 19:46
https://en.m.wikipedia.org/wiki/Surfboard
The longboard is primarily a single-finned surfboard with large rounded nose and length of 270 to 370 cm (9 to 12 ft). Noseriders are a class of longboards which enable the rider to walk to the tip and nose ride. These are also called "Mals", a shortened form of "Malibu boards". They range from 270 to 430 cm (9 to 14 ft) long, or 90 cm (3 ft) taller than the rider in overall length. The advantage of a longboard is its substantial buoyancy and planing surface enable surfers to ride waves generally deemed too small to propel a shortboard. Longboards are more suitable for beginners because of the board's size and ease of catching waves. In the proper conditions, a skilled surfer can ride a wave standing on the nose of a longboard with their toes over the nose's edge: in this way, with the "toes on the nose", the surfer can "hang ten". Compared to the shortboards, longboards are considerably easier to learn on as they are capable of achieving stability, thus making the transition quite difficult.[37]
