Mirage 532, 15.9kg
Добавлено: 19 мар 2018, 16:24
https://www.mirageseakayaks.com.au/mirage-532M I R A G E 532
Designed for performance, the Mirage Sea Kayaks 532 combines speed with dependable handling in challenging conditions for a wide range of paddlers.
A complete redesign of the famous 530, the Mirage Sea Kayaks 532 is a great all-rounder; built for speed and efficiency, while also being sporty and easy to control when maneuvering. Extra volume has been added behind the cockpit, enhancing the hull shape to suit a wider range of body types.
Perfect for:
• Small to medium plus sized paddlers, from beginner through to advanced paddling skills
• Fitness paddling and day touring to multiday touring in more confined bodies of water e.g. lakes, estuaries, to coastal environments
Mirage Sea Kayaks Australia
Specifications:
Length: 5.3m
Beam: 56cm
Weight:
(all weights are based on an average weight)
Carbon (IRT) = 16.9kg
Innegra Hex / Kevlar (IRT) = 17.5kg
Kevlar (IRT) = 18kg
Kevlar = 21kg
Fibreglass = 24kg
Special Build:
Feather Light (IRT) = 15.9kg
Volume:
Rear Hatch: 70L
Front Hatch: 50L
Day Hatch: 25L
